Need advice for seal replacement
Punch'Eau
Vessel Info: 2000 350 Mariner
Has thanked: 25 times
Been thanked: 7 times
Re: Need advice for seal replacement
Post by Punch'Eau »
km1125 wrote:QR_BBPOST A pic of the INSIDE on the rudder shaft might yield better answers, because it will show what type of seal is there. If it is just a packing gland then just tightening it a bit might be all it needs (as suggested above).
3 weekes later here is a pic of the inside. It was leaking from around the shaft
Yea, that's a regular stuffing box. Loosen the jamb nut and tighten down the large nut a bit and it'll likely stop the leak. That stuffing doesn't wear out nearly as quickly as the prop shaft (obviously because the rudder shaft isn't spinning!), so it's likely that all you need is some adjustment.
Punch'Eau
Post by Punch'Eau »
km1125 wrote:QR_BBPOST Yea, that's a regular stuffing box. Loosen the jamb nut and tighten down the large nut a bit and it'll likely stop the leak. That stuffing doesn't wear out nearly as quickly as the prop shaft (obviously because the rudder shaft isn't spinning!), so it's likely that all you need is some adjustment.
Thank you very much
