Used boat parts, used Carver boat parts, trailers, dinghies, outboards, props...everything but the boats they were attached to. ALL ADS ARE FREE - USERS MUST HAVE AT LEAST 10 POSTS TO PLACE AN AD
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
Hey Kend, Mine were attached with what appeared to be 5200 or similar product. I think I used a solvent to soften it up then a razor, a knife blade and a flat tip screwdriver to get it out of the groove once separated. It was a pain in the A$@!
Maybe this will help someone else, by suggestion of a friend I used a heat gun and heated up along the slot on the aluminum corner piece and put a screw driver just behind the edge at the top of the plastic and it came apart in a few minutes. Now I just need to get the plastic cut and drilled.
Kend, I have a 92 330 Aft cabin I was wanting to replace the dodgers on who was your supplier for the panels. I see you’re from Grosse Ile, we keep our boat in Wyandotte. Hope to cross paths. Thanks Mike
Wayne162 wrote:If you are looking to do it yourself if the parts are not available from Carver, try Mcmaster-Carr. I purchased a 4' x 8' sheet of UV protected acrylic panel that I cut for a snow plow blade insert. They are on line and supply bulk composite material in whatever size you specify. My sheet ran about $80.00.
I just looked on their site. $214 for a 4’x8’ sheet of 1/4”. No quote on delivery yet.
Bruce Bennett Bentone23@sbcglobal.net 1996 355 Aft Cabin Central California Boating on the Delta and SF Bay
KEND wrote:I also have two cracked panels for my 1991 33 aft, My problem is I cannot get the corner piece off the plexiglas panels on either side, so without separating the plexiglas I cannot use the corners. They seem to be locked on, maybe glued, not sure , all I know is no matter what, I have even tried to separate them using a razor knife to scrap inside the edges. No matter what I try no luck, any suggestions ?
Shatter the plastic out with a chisel.
I know I used mineral spirits and poured it down the channel of the corner and let it sit for bit. I did use a knife tip to break the bond once is became soft.
