Bus bars
Been thanked: 1055 times
Re: Bus bars
Postby km1125 » March 18th, 2017, 8:44 am
bud37 wrote:Source of the post I think if I remember right there are two grounds from the gen.....one to the battery from start circuit etc...and one from block and case that goes to the port engine block post.....its been a while, won't be long now just another couple months :cry:
There should be two. One that carries the starting current from the battery, that gets connected to the battery (and in this case, via the negative buss bar). The other "ground" is the BONDING wire, which should connect all thru-hull-connected devices (engines, rudders, etc) AND ALL A.C. generating devices as a safety ground. The first wire should be rated to handle all the starting currents, the second AT LEAST as large as the A.C. output is capable of.
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Re: Bus bars
Postby tonyiiiafl » March 18th, 2017, 4:54 pm
Feez, where did you place this house bank of 4 batteries?? Same setup I am looking to build.
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Re: Bus bars
Postby dsolo » March 18th, 2017, 8:20 pm
Frazer, help me out with the Victron energy monitor location? I am awhere of the meters on the electrical panel. I do not know of a DC load monitor? Need help
Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo
454 EFI Crusaders
Name: La Belle ll
Re: Bus bars
Postby dsolo » March 18th, 2017, 9:40 pm
I do not want to hijack the intent of this post. Please disregard my questions on amp meter. Sorry
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 65 times
Re: Bus bars
Postby feeez » March 19th, 2017, 12:11 pm
dsolo wrote:Source of the post I do not want to hijack the intent of this post. Please disregard my questions on amp meter. Sorry
No worries!! I actually like the fact that some of these topics take a life of their own.
The Victron monitors the Voltage, Amperage flow (-/+), Stage of charge, and the number of amp hours consumed from the battery bank.
Cheers
Fraser
Former 2001 350 Mariner owner
feeez
Re: Bus bars
Postby feeez » March 19th, 2017, 12:16 pm
tonyiiiafl wrote:Source of the post Feez, where did you place this house bank of 4 batteries?? Same setup I am looking to build.
Here is a pic of the setup. Cleaning up a the wiring this year and building a battery box. It is messy at the moment but I am getting there!!! :beergood:
cheers
Fraser
