Engine room lights on my 356
Rich W
Vessel Info: 1993 350 Aft Cabin
Sandy's Riches
Been thanked: 2 times
Re: Engine room lights on my 356
Postby Rich W » September 25th, 2018, 8:25 pm
Thanks for the reply, Midnightsun. I understand the benefits and general safety of LED lights. However, I can't put anything in my gasoline engine room that isn't Ip 67 rated for ignition protection. That rating implies that the electrical devices having that rating have been tested to comply with the standard. Too much to lose if something goes wrong....the manufacturer you reference sells fixtures that have met the requirements of the standard. The standard comes from the US code of federal regulations,183 which covers marine industry.
Of course, this means that they can charge me greatly for it. Oh well!! Thanks again.
Rich W
Bentone23
Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders
Has thanked: 57 times
Been thanked: 5 times
Postby Bentone23 » November 9th, 2018, 9:38 pm
Is that what the switch that has the green lamp below it is for? My green lamp lights up when the switch is switched on. My manuals say nothing about engine room lights.
Bruce Bennett
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » November 9th, 2018, 11:59 pm
Bentone23 wrote:Source of the post Is that what the switch that has the green lamp below it is for?....engine room lights
Yes, engine room lights.
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » November 10th, 2018, 12:27 am
Rich, I believe IP 67 is a water proof rating and not an ignition rating. The original halogen lights were not ignition proof rated either.
Unfortunately, I believe many items such as the water pumps, a/c pumps and battery chargers on these boats from the factory were not ignition proof.
:banghead:
Postby Viper » November 10th, 2018, 11:16 am
It's not always a single component of a piece of hardware that needs to be ignition proof, sometimes it's the assembly itself. A light bulb for example may not have an ignition proof rating but under the right conditions could cause a fire or explosion hazard. In this example it's the fixture the bulb is in that should be ignition proof. Sometimes it could be an ignition proof component but the way the connection is made may allow for movement that could cause a spark. Again, in such a case, the assembly or enclosure should be the first line of defense, not just the component inside.
Engine room lighting falls into a special category IMO. It's not enough for them to be simply ignition proof in a gasoline bay, they must be robust and not easily broken or damaged even in a diesel application. When I'm crawling around in an engine compartment with the lights on and working on a gasoline related issue or anything else for that matter, I don't want to have to worry about bumping into a flimsy fixture or live wire that could put me in a dangerous position. Even if ignition proof ratings aren't required for a given application, a non-marine assembly that comes with wire pigtails for example don't use marine wire and aren't built/assembled with the same considerations in mind. ALL engine bays require marine wire for more reasons than just their anti-corrosion properties. An unnoticed accidentally broken fixture, bulb, LED, wiring, etc. in a circuit that gets powered up later is an explosion hazard in a gasoline application and a fire hazard in ANY application.
