Port engine stalls while running after a while
Ctmangrum
Vessel Info: 1977 Carver Mariner 2896
Has thanked: 37 times
Re: Port engine stalls while running after a while
Post by Ctmangrum »
The coil im replacing
With two engines I would just swap the coils from one engine to the other. Then, if the problem follows the coil, you KNOW the coil was the issue. If the problem just goes away after you replace the suspect coil with a different coil, then you really don't know if it was the coil that was the issue or something else you disturbed while changing the coil.
Ctmangrum
Post by Ctmangrum »
Anyone know the ohm reading for a new engine coil? My old coil is showing 10.2 primary resistance and new one is 7.5. Supposedly direct replacement.
Ctmangrum
Post by Ctmangrum »
Forgot to update. Everything seems
Fine once I changed the coil. Did a quick tune up while I was there also. We will see.
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Post by Phrancus »
Nice to get to the source of the problem you had. :down: enjoy, celebrate!
up to the next... :-D
Small curious question as a non-native speaker: what do you mean with 'a tune-up while you were there? '
KandJ72
Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process
Has thanked: 20 times
Been thanked: 3 times
Post by KandJ72 »
As far as the coil resistance, primary should be ROUGHLY .5-3 ohms on primary, secondary 6000-15000 ohms.
This is if your running OEM PCM replacement coils, aftermarkets will usually run a little higher except for high output like Accel, Bosch etc. I installed the Hot-Spark ignition conversion kit in my '76 Carver 3396 with twin 351W, LOVE them. Easy start EVERY time! Much less expensive than Pertronix. Never mess with points again.
SGI390
Vessel Info: 1993 Carver 390
Crusader 454 Engines
Post by SGI390 »
I am having a similar issue with my Crusaders. I cannot seem to get enough fuel to the motors so after cleaning several fuel filters and replacing I’ve checked all the lines from the tanks to the valves. They are not clogged. The engines both fail at the same time even when pulling from separate tanks. I have engine cleaned all the screens and remove the anti-siphon valve all together. Any thoughts?
Elliott Fann
1986 26' Carver Santa Rosa
1995 26' World Cat
31' Contender Open
1993 Carver 390
