I am looking at changing my throttle set and cables this spring before my 1987 Santego 27' goes in the water. From my research it looks like the Teleflex CH7800 control W/tilt,trim on handle is the best choice for a throttle set.
Has anyone here done the replacement themselves?
What length of cables would I need to purchase for the replacement.
The boat is currently out of the water and I was looking at doing this before I put her back in in mid-may.
Throttle Replacement Carver 27' Santego
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Throttle Replacement Carver 27' Santego
If you have the owners manual, it states what cables were used for each engine option. I know Vovlos used different cable lengths than Mercs, and I don't really know what size they would be. They also should be labelled on the end of the cable jacket...either end really, but usually not the control end.
Kenny
T-Merc 350 Mag MPI (300hp)
- PhotoHog
- Vessel Info: 2003 Carver 444 Extended Salon (purchased late 2021)
Cummins 370s
Freshwater - for now. - Has thanked: 1 time
- Been thanked: 3 times
Thanks - I don't have original manuals and the PDFs that I have found don't contain the cable specs.
Unfortunately access to the boat to check the size of the cables is not possible for a few weeks, she is locked in a compound that will not open until mid-May and I was hoping to order them to have on hand as soon as we can get access.
- Ramsport47
Give the service department at Carver a call with your hull number...they should be able to help you out. I always talk to Bret Temple...really good guy!
Kenny
