Hey - Keep Your Cool Man!
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Post by After Taxes »
Here's a great little morning project that helps your AC/Heat unit running efficiently. Wash the filters. I recall a friend who complained that his AC wouldn't blow very cold. We found his filters clogged with dust.
I love how Carver put the primary air return filter grill on a hinge for easy access.
Take out the metallic mesh filter and wash in hot soapy water.
Next, locate your AC unit. Mine is under a salon seat. There is a light plastic mesh filter directly against the unit, which easily slides up or can be gently pulled away. This needs a bath too.
Clean filters will protect your valuable AC unit and allow it to cool and heat with maximum efficiency.
Happy boating.
Steve.
MerCruiser MX 6.2
Lake Simcoe, Ontario
