1987 Mariner water system
Topic author
eanderson560
Vessel Info: 1987 Carver Mariner
Postby eanderson560 » June 8th, 2015, 3:02 pm
I'm having some trouble keeping my fresh water pump working and now the onboard pump is pushing water out the shore water receptacle. I have owned this boat for 3 years and installed a fresh water pump 4 times. It keeps dying on me. Is this a common problem? Also last weekend I noticed the water tanks draining really fast and found that the fresh water pump was pushing water out of the shore water receptacle on the back deck. Anyone have any advice?
Has thanked: 53 times
Been thanked: 426 times
Re: 1987 Mariner water system
Postby waybomb » June 8th, 2015, 6:48 pm
There should be a check valve. Follow the hoses and you'll find it. I bet it is stuck.
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 65 times
Postby feeez » June 8th, 2015, 8:26 pm
I had the same problem in my last boat. In my case the shore receptacle contained the check valve and it had to be replaced.
Fraser
Former 2001 350 Mariner owner
Jeffnjoni
Vessel Info: 1986 carver mariner
Postby Jeffnjoni » October 12th, 2015, 12:19 pm
I have an 1986 mariner 36. Where can I find the pressure water pump. I've looked everywhere I can via acsess hatches
Postby waybomb » October 12th, 2015, 5:43 pm
Forward stateroom. On the floor between the door and the bed is a cover. It's under there.
Users browsing this forum: No registered users and 54 guests
