Bilge Wont Shut Off- under galley floor
Topic author
Reardon
Vessel Info: Carver 404 2000
Postby Reardon » June 20th, 2015, 9:08 pm
Hi
I have what I believe to be a bilge pump that wont quit running. I am not sure what fluid it is suppose to move, but I think it is related to the forward head. It is under the galley floor board and here is what is really weird. I can shut down all the power (AC and DC), and it still runs.
Anyone know what that bilge goes to and why it would run continuously.
Rich
Has thanked: 53 times
Been thanked: 426 times
Re: Bilge Wont Shut Off- under galley floor
Postby waybomb » June 21st, 2015, 8:47 am
If you kill the battery switch and it still runs it must be a bilge pump. There should be some Fuses by the switch. Those are for the pumps. Take them out one at a time until the pump stops. Now you know which one. It's probably a bad float stitch by the pump.
Make sure you put the other Fuses back in!
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » June 21st, 2015, 10:29 am
I was going to add the forward shower sump but it would shut off with the main battery switch set to off. Opening the galley floor hatch will give you direct access to the forward bilge pump.
..Aaron
'99 404 CPMY
SeaDragon
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Postby After Taxes » June 23rd, 2015, 8:20 pm
A bad float switch will cause a pump to run continuously. Water has made its way into the switch and it is time to toss the float. Some have a separate float, and if this is you, just identify the float and replace it.
If the float is internal to the pump, then toss the whole thing.
Had this issue on previous boat.
MerCruiser MX 6.2
Lake Simcoe, Ontario
Users browsing this forum: No registered users and 101 guests
