My 1995 Carver Santego 380 has lights that uses a fixture that simply penetrate a flat wire and is held in place by a catch that hooks into a groove. I am replacing the lamps with LED's, but the plastic fixtures are breaking. Probably heat from the incandescent lamp's heat. I looked for a manufacturer, but only found a UL symbol. Any ideas for a source for them? How about a replacement idea? The ones in the berth are the problem. The ones by the wet bar seem OK.
John
Lighting fixture source needed
- jflongwell
- Vessel Info: Santego 380 1995
