Oil dipstick reading
Chris86
Vessel Info: 1986 ACMY 4207, Twin 454, with previous owner's self righteous modifications.
Has thanked: 5 times
Post by Chris86 »
Hi all. I have twin 454 Crusaders in a 1986 4207. I bought the boat about 3 months ago. The oil in both mains looks practically new. But how can you tell if they need oil with the mains slanted like they are? With the right amount of oil at an oil change, the dip stich would show way higher than the marks on the stick. Correct? Help!!
Been thanked: 492 times
Re: Oil dipstick reading
Post by waybomb »
If you haven't changed the oil, drain the old and add the correct amount. Then look at dipstick.
Should ease your mind.
Post by RGrew176 »
waybomb wrote:If you haven't changed the oil, drain the old and add the correct amount. Then look at dipstick.
Don't you just love it when a problem has such a simple solution. Wish they were all that simple.
