Jus Chillin
Juschillin
Vessel Info: 2001 396 Cummins powered
Jus Chillin
Post by Juschillin »
Hi guys - new to the forum but I have a question about my 2001 396. How do you remove the salon bulbs?
Ramsport47
Been thanked: 59 times
Re: Jus Chillin
Post by Ramsport47 »
The lenses should turn slightly and pull down. The bulbs are a two prong G4 type bulb that just pushes into the socket. Take care with the new bulb in not getting any body oils on them as it shortens the bulb life
Kenny
T-Merc 350 Mag MPI (300hp)
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Re: Jus Chillin
Post by feeez »
Best advice here is.... when you take them out throw them in the trash and replace them with LED.
Former 2001 350 Mariner owner
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Jus Chillin
Post by Lyndon670 »
A great tip to remove the ring is to use a small oil filter wrench - the type that decreases in diameter the more you turn it.
+1 on the LEDs.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Juschillin
Re: Jus Chillin
Thanks all
Juschillin
Re: Jus Chillin
Hi everyone - 2 questions for ya - does anyone know what color best matches the engine white on my 396? And where in the world is the reservoir for the hydraulic steering?
Re: Jus Chillin
Post by mjk1040 »
The fill port should be on the dash at the helm I do believe just to your right of center. Call a cummings dealer and they should be able to give you the color code for that engine. Don't know why a satin white restoleum wouldn't be pretty close. Check the Carver web site, they have a lot of parts diagrams. Mike
