Fresh Water Tank Gauge Not Working
Been thanked: 243 times
Postby mjk1040 » March 1st, 2016, 6:01 am
:help: 1998 Carver 355 MY, my fresh water gauge in the galley does not register the water level in the tank. Always empty.
Checked the DC voltages on both the sender the gauge and all points read pretty much the same on both. Voltage in and out at both ends. Pretty sure wired correctly, if I turn off the breaker for this unit I believe the gauge floated up, as soon as I turn the power back on it went to empty. Any Ideas, sender unit? Gauge? Though someone would have run into this and could advise. Thanks!
Mike
Has thanked: 457 times
Been thanked: 1690 times
Re: Fresh Water Tank Gauge Not Working
Postby Viper » March 1st, 2016, 10:03 pm
Short out the sender wire at the sender to ground and see if it pegs the needle. If it does, the gauge is working and the sender is faulty.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » March 2nd, 2016, 9:16 am
Can almost always bet on the sender. Depending on the corrosion or the softness/hardness of your water, you may be able to clean it up.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Postby SplashyLady » March 2nd, 2016, 10:16 am
X3 on the sender. If you get a new one, go with a Wema sender if you have the room to get it inside the tank. The Wemas are much more reliable than the lever-type senders. They use the same mount and have the same connections, but you need to order the correct length for your tank depth. Just measure your tank depth and order the corresponding sender length. :down:
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Postby mjk1040 » March 2nd, 2016, 2:27 pm
Thanks Guys! Love this site, someone's been there and done that!! And boy it sure saves a lot of time.
Mike
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » March 2nd, 2016, 3:34 pm
Since you have it out, drop it into a bucket of CLR and let it sit overnight. Worst case nothing changes, best case it works perfectly or minimum you have a backup.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Postby mjk1040 » May 3rd, 2016, 4:51 am
Well you all were right on the money, it must have been the sender, it started working again on its own when I re-commissioned her this spring. Maybe the RV anti-freeze descaled it over the winter? It ain't broke, don't fix it! We'll see if it works all season? Feels good to have her on the water again. Mike
dscalarm
Vessel Info: 2003 Carver 396 motor yacht
twin 8.1 Volvo Pentas.
Has thanked: 6 times
Postby dscalarm » August 7th, 2021, 4:27 pm
Does anyone know where the sender is? 2003 396. I have the empty reading on the gadge.
:captain:
hoverlover
Vessel Info: 2002 356
Postby hoverlover » July 10th, 2022, 5:59 pm
Water tank is under the master berth. Lift the mattress to revel the hatch for the bilge. The tank should be the large plastic white one, and the sending unit is in top and has two wires going to it.
