Raymarine C80 and AutoPilot
- feeez
- Has thanked: 52 times
- Been thanked: 65 times
Problem:
After I create a route with the MFD and start to follow that route I want the Autopilot to join the party. According to the manual for the Autopilot we set the autopilot on "Auto" and the MFD following a route. When this is all happening the next waypoint becomes visible on the autopilot screen. When I press "Track" on the autopilot it beeps (very annoyingly) and displays the error "No navigation data". It seems they are talking to each other as the waypoint shows up on the autopilot.
I foresee some trips this season with some relatively long straight runs so this would be a good thing to have working.
As always thanks in advance for your thoughts and opinions.
Fraser
- Has thanked: 576 times
- Been thanked: 1205 times
Re: Raymarine C80 and AutoPilot
- feeez
I am relocating my MFD this year, I will check all the easy stuff and try to get a better understanding of the set up.
I will post what I find.
Fraser
- Has thanked: 455 times
- Been thanked: 1669 times
feeez wrote:Source of the post No I have not..... annoying for same reasons you outline
Fraser
That would be great, I have the C 80 as well and the more I can learn about it, the better......its all up to you now....
- feeez
Viper wrote:Source of the post I wonder if the ST70 is picking up the GPS sentences. Will it display positional data as the vessel moves?
This is the strange part of this. When I have the MFD following a route the waypoints are showing up on the ST70 but when I press "Track" it just comes back with the no navigation data error.
Fraser
Has this unit ever worked for you?
- feeez
Viper wrote:Source of the post Yes but getting a waypoint is different than needing gps/heading data to get to that waypoint. Check the simple things first like all the connections and system setup.
No it has not worked since I owned the boat. I will do the connection check when I move the MFD this season. We all know that with electronics sometimes an un-plug and re-plug can solve a myriad of malfunctions.
I also want to get my VHF hooked up to the system properly this year also..... the never ending array of projects when boating......
I see what you mean about the waypoint. Although the ST70 is getting "a" waypoint if there is no heading data coming with it the "no navigation" error would be justified.
- feeez
Viper,
From what I have seen the ST70 is functioning properly. When engaged it holds the boat at a constant heading that matches the GPS and the SOG data is consistent with the GPS.
Users browsing this forum: No registered users and 3 guests
