One of our engines has a oil pressure of 80 running hot what maintenance would you recommend ???
Thank you
Oil pressure question
- Bankerbiz87
- Vessel Info: 1982 Carver Mariner twin 220 engines 28ft
- Has thanked: 10 times
- waybomb
- CYO Moderator
- Been thanked: 492 times
Re: Oil pressure question
I'll bet it is not 80psi but a faulty gauge or sender indicatingh 80.
Your mechanic can remove the sender and screw in a mechanical pressure gauge to verify oil pressure.
If in fact it is at 80, you must have a stuck relief valve and need to get that fixed. I've seen oil filters blown off of engines when a valve gets stuck.
And then usually something caused it to get stuck, metal, and it came from somewhere.
