airconditioning
scoobychonx
Vessel Info: 1991 carver 36 aft cabin twin cummins
Has thanked: 5 times
airconditioning
Post by scoobychonx »
Has anyone had their marine air converted to run on a newer refrigerant . Thanks
Re: airconditioning
Why? Pretty sure it'll require a new compressor at least. The only reason I can think of going through the trouble is if there's a problem with the current one and it has to be replaced anyway. Having said that, the cost to do it is such that it usually makes more sense to simply replace the whole unit in some cases given that spending money on a new compressor and still having a 20 year old air conditioner may mean that something else is bound to fail on it in the near future like the fan, control board, evaporator, etc., all pricey items as well.
Re: airconditioning
Post by mjk1040 »
I agree with Viper and R134 will not cool like R22 refrigerant. Mike
Been thanked: 492 times
Re: airconditioning
Post by waybomb »
When we bought our 3697, the forward ac was missing. It is right under the bed. The older units were loud. I bought a new Webasto. The air coming out of the vents is more noisy then the unit itself.
If you have any issue with your older ac, I strongly recommend this Webasto, but I would also guess any unit with a scroll compressor will be similarly quiet.
scoobychonx
Re: airconditioning
. Thankyou all. The only reason I am wanting to change the refrigerant is because In England r22 is illegal and as mine require re gassing and I'm needing a replacement
CaptBob
Vessel Info: Shopping....
Been thanked: 33 times
Re: airconditioning
Post by CaptBob »
waybomb wrote:Qr Bbpost When we bought our 3697, the forward ac was missing. It is right under the bed. The older units were loud. I bought a new Webasto. The air coming out of the vents is more noisy then the unit itself.
I appreciate this info. I'm in the middle of deciding what to do with my salon ac unit. I have a compressor hammering and on it's way out. I've been looking at replacement units, and looked into those Webasto after reading your post. A quiet unit would be a good thing!
Capt Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... :captain2: )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
Re: airconditioning
Post by waybomb »
Go shopping as well. Prices are all over the place.
Re: airconditioning
Post by g36 »
mermaid marine ac are good units with a 5 yr warranty currently have 2 and 1 on another boat, they would be a brand to check out
http://mmair.com/marine-division/marine ... ditioning/
Re: airconditioning
Post by mjk1040 »
I'd bite the bullet and go with a new unit and make sure it has a stainless steel drip pan too. Converting to R134 also requires changing o rings and a few other parts compatible with R134. Mike
Re: airconditioning
Post by tomschauer »
Just an FYI, you can get some "drop in" CFC free replacements for r-22 that only require recovery of the existing refrigerant and evacuating and recharging the system but your capacity will drop about 20%.
Converting to 134a requires you remove all of the oil (a difficult task with rotary compressors) and replace the oil and refrigerant. You will also need to replace the expansion valve(s) and add a filter dryer. As mentioned above with an older unit, its not worth the time and $$$.
