Crusader 8.1 2005 Oil requirement
- Carver362005
- Vessel Info: Carver 366 2005
I am a new owner of a 2005 366 Carver with 8.1 Crusader gas engines and don't know what kind of oil to use. The oil fill cap on the motors say ASE 15W 40 however the only 15W 40 I can find is Diesel oil. This can't be right? Any recommendations ?
Re: Crusader 8.1 2005 Oil requirement
Welcome to the forum........if you got the original carver case with the owners manuals in it, there is probably the engine manual ....check to see what it says.....sae 15w40 is common and if you are referring to rotella t then there is a gasoline rating on it or there used to be ( check the back). Lots of guys use it with no issues, I have for years but check your manuals to be safe.....
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Rotella has a dual gas/diesel rating. However, any good quality oil will be perfect. even a West Marine brand. I am partial to Mercruiser/Quick Silver 25w40 myself.
- Carver362005
Thank you both for your replies but the only 15-40 I can find including Rotella say on the front of the container that it is for Diesel. It does not mention gas.
Check the back of the container for all the API ratings, that will tell you........
- waybomb
- CYO Moderator
- Been thanked: 492 times
Been using Rotella T 15 40 in all my boat engines for years. All gas. Currently 6 big blocks, 2 454 crusader, 1 588, and 3 572.
Mobil 1 in the cars
Mobil 1 in the cars
- mjk1040
- Been thanked: 248 times
Rotella T is the only inexpensive oil out there that contains Zinc. Zinc has the molecular properties to help keep the oil clung to metal parts so there's never a dry run. Its for both gas and diesel. I too use nothing but Rotella T in my Crusaders 7.4L and know may other users that put it in every engine they own and have for years. Mike
Mike
