I believe the 48" florescent bulb fixtures behind the valences on 1987 3807 Carver are 12 volts? What are the florescent bulbs? 12 volt DC or 120 volt AC and the fixture converts?
Ron
48" floresent bulbs on 1987 3807 Carver
- quickdecision
- Vessel Info: Carver 3807, 1987
- Been thanked: 23 times
- waybomb
- CYO Moderator
- Been thanked: 492 times
Re: 48" floresent bulbs on 1987 3807 Carver
120vac.
Turn the lights on. Turn the main shore power breaker off. I bet the lights go out
- quickdecision
Valance lights are run from the 12 volt side of the panel. Ballast in light fixture converts to 120 volt. All light fixtures are the same. On the 12 volt side. Vanity lights, and lights in both heads are 120 volt. Just got everything powered up over the weekend.
Ron
Ron
