Looking at a 406, has the LOA listed as 46 ft. Seems a lot longer than the other 40Xs ... bad listing? Bigger boat?
Thanks in advance.
406 - overall length?
Re: 406 - overall length?
I have a carver brochure from 1998. It shows the 405 as 42'3" LOA with platform and 13'10" beam. I believe the 406 is the same hull with nicer windows and portals.
Unless someone added a swim platform extension, that could bring it to 46'.
PJHoffnet
- Has thanked: 55 times
- Been thanked: 18 times
Thanks. Took a look at the listings pictures, no swim platform ... I'm guessing just and error in the listing.
If you want to check out any Carver specs you can go to Carver Yachts website and under owners there is a drop down where you will find old brochures, manuals and specs........
