Swim platform
Topic author
Ghyden
Vessel Info: 2003 366 Motor yatch. Twin 6.2 320 hp each
Swim platform
Postby Ghyden » September 25th, 2013, 1:29 am
I recently purchased a 2003 366. I am wanting to have an extended swim platform installed. Boat is on a freshwater lake in the Midwest. I also want to install underwater lighting. Can anybody steer me in the right direction on the platform. So far I have been searching the Internet. I don't know if these are premade or if I will have to have one custome made. Any ideas???
SHEMP
Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht.
Been thanked: 4 times
Re: Swim platform
Postby SHEMP » October 6th, 2013, 11:31 pm
Were these extended platforms available from Carver as original equipment? Perhaps they might have the molds . I highly doubt you will find a swim platform that will fit your boat. Carver would have only built as many as were ordered. If they have the molds its not likely they will let you use them. I think your best bet is to find a good Fiberglass fabricator in your area and have one built .
I'm guessing between $3000 to $5000. Measuring boat and platform , making plug, making mold, pulling part, finishing the part and installation. Keep in mind the platform is through bolted to the hull sides and transom.
You might be able to offset the cost by renting out your mold.
Good luck
Shemp
Ramsport47
Been thanked: 57 times
Re: Swim platform
Postby Ramsport47 » October 7th, 2013, 12:36 pm
Try www.swimplatforms.com or www.myswimplatform.com We've used them both. They will both custom make a platform for your boat, although swimplatforms.com do have a size limitation where the other one does not seem to.
Kenny
T-Merc 350 Mag MPI (300hp)
Topic author
Ghyden
Re: Swim platform
Postby Ghyden » October 23rd, 2013, 12:34 am
Thanks for the feedback.
