live wells 350 Mariner
mgd553
Vessel Info: 1998 Carverr 350 Mariner
Post by mgd553 »
I've got 2 live wells in the bow. I'll never use them as live wells so I want to open the drains but they are plugged. I cannot figure out how to unseat the plugs. Any ideas? thanks!
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Re: live wells 350 Mariner
Post by Agriman »
The wells you refer to are access to your waste pumpout and fresh water fill. Mine have never had a plug. You might try air pressure from the drain port on the side of the hull to blow any debris out of the hose. You can access the hose for removal if necessary from under the front seat by the A/C unit. These wells are for fender storage etc.
Hope this helps.
