1987 Carver Montego Sea Strainer Location
1987CarverMontego
Vessel Info: 1987 Carver Montego 3257
Post by 1987CarverMontego »
We are new owners of a 1987 Carver Montego 3257 and cannot locate the sea strainer for the engines or ac unit. We easily found the generator sea strainer and cleaned it out but cannot locate the other 3. Please help!
Re: 1987 Carver Montego Sea Strainer Location
Is the thru-hull visible and the hose from the thru-hull to the raw water pump?
It should be in that line.. .but if not you might not have one. Mine didn't come with ones from the factory.
Not all models of earlier vintages had strainers installed for the engines. I don't think I've run across an AC install without one though.
