FM Antenna location and type?
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
Just a quick question. Where is the FM antenna from the radio mounted in the salon? What kind of antenna is it?
Re: FM Antenna location and type?
The one in ours appears to be original and is just one of those antennae wires, and is hanging behind the entertainment centre ...I couldn't find anything else.......
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
That is what most boats seem to have for a radio AM/FM antenna. I have only seen a few boats that have an actual antenna.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Mine has a 3ft whip mounted on the port side of the fly bridge. I assumed it is a factory install but don't know for sure.
..Aaron
..Aaron
'99 404 CPMY
SeaDragon
SeaDragon
- waybomb
- CYO Moderator
- Been thanked: 492 times
I have an 8' Shakespeare fm antenna on the other side of the arch from the vhf antenna. If for no other reason, to keep the vessel symmetrical in appearance
- amanphoto
Has anyone had luck putting a VHF antenna splitter in? Does is degrade the VHF performance?
https://www.westmarine.com/buy/shakespe ... ecordNum=1
I also have a 3' fm antenna on the port side of the bridge, seems to be factory as the wire is bundled with the rest.
I used an identical band splitter on a previous boat. I didn't notice any change in VHF performance, however, if I had the vhf and the radio on, I would often hear the vhf through the radio speakers. It seemed this only happened with a strong local vhf signal.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
amanphoto wrote:Qr Bbpost Has anyone had luck putting a VHF antenna splitter in? Does is degrade the VHF performance?
I don't recommend a splitter - seem to impact performance both ways. If you are in a very remote area, consider a small amplified antenna mounted somewhere in the cabin (even behind a panel is OK). Terk makes a good one and one I currently have uses a 12vDC power supply:
https://www.amazon.com/TERK-Amplified-S ... fm+antenna
http://www.ebay.com/itm/Terk-Tower-Indo ... SwDNdVpp2p
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Lake Norman, NC
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
I had the splitter on my Silverton 42C, and had no problems. I am about to order one for my 506.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Lyndon, did you order your splitter?
If not let me know, while cleaning the garage I found a shakespeare 4357s splitter. Brand new never used. I am bit AR and usually buy two of everything.
If interested you can have it for $30.00 plus shipping at cost, probably about $6.
Let me know
Tom
Let me know
Tom
