What glue should I use?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Post by amanphoto »
The decorative foam backed vinyl wall covering in the bedroom on my Mariner 350 is comming loose. What do you recommend I use to stick it back down?
Re: What glue should I use?
Remember what your mom said....dont pick at it!! :-D ......anyway 3m 777 spray adhesive is probably ok,check the can instructions for foam first, but I have used it before, don't need much....... :beergood:
