Rear fuel tank question
- PhilH
- Vessel Info: Carver Californian 45 M/Y, 1990 Cat 3208 diesels
- Has thanked: 5 times
- Been thanked: 3 times
- Contact:
Any help will be appreciated. Thanks. ps, LOVE the boat !!
- Been thanked: 1043 times
Re: Rear fuel tank question
- PhilH
- Contact:
Phil
- Has thanked: 579 times
- Been thanked: 1210 times
PhilH wrote:Source of the post OK, thanks, that is what I thought I would try when I get down to the boat. If it leaks, where the heck do we get a new tank from?
Phil
There are a number of tank makers in FL.....google- marine tanks Florida.......
- Jeff D
- Vessel Info: Californian 45
I have two places to observe and gain access to the aft tank on my Carver. Under the mattress in the aft cabin are two access panels that can provide you access to the bilge. If you get into this area, you can see the aft end of the tank with the shutoff valves. You can also check the trim tab tank and the steering hydraulic fluid tank. The other place is in an area located under the storage area, next to the steps going down into the aft cabin. This is the location of the aft HVAC in my Carver. If you remove the panel, you will see the top of the HVAC. Just forward of the HVAC should be an access hole where the fuel return lines and a second airline connects to the front of the tank. You need to be a bit of a contortionist to get into this hole, but it is there. Hope this helps.
Jeff
Users browsing this forum: No registered users and 96 guests
