Carver 3207 Revised - 2015 projects & bow thruster
Mkemper
Vessel Info: 86' carver 3207 Aft
[IMG]http://i1238.photobucket.com/albums/ff498/mjkkemper/null_zps98e8d64b.jpg[/IMG]
Been thanked: 8 times
Post by Mkemper »
About 3 years ago I purchase a 86' Carver 3207. When I purchased it I really liked the layout out with the lower entrance to the bridge and aft cabin. However I felt it needed a better access to the swimplatform and was lacking a radar arch and aft hardtop. I wasn't a big fan of the tube ones.
Anyways I have been busy updating. I will start from the beginning and catch up to my latest updates
I have a large library of pictures below:
http://m1238.photobucket.com/albums/mjkkemper
The beginning
Mkemper
Re: Carver 3207 Revised
Post by Mkemper »
The swimplatform molds
Mkemper
Post by Mkemper »
The layup
Mkemper
Post by Mkemper »
De-molding and mounting
Next I can update the post on the hardtop and fiberglass radar arch if any is interested
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Post by AaHubb »
Hi Mkemper, that was quite a project with impressive results (I followed it over on YachtForums). I have a question about your sat tv dome mount. That appears to be an RV style unit instead of a marine version. My question is how did you attach it to your narrow radar arch. I am looking at a similar unit but am concerned about providing a solid mount.
'99 404 CPMY
SeaDragon
Mkemper
Post by Mkemper »
AaHubb wrote:Hi Mkemper, that was quite a project with impressive results (I followed it over on YachtForums). I have a question about your sat tv dome mount. That appears to be an RV style unit instead of a marine version. My question is how did you attach it to your narrow radar arch. I am looking at a similar unit but am concerned about providing a solid mount.
Thank's. I figured I'd catch up before posting this years projects
Below is the mount. When I made the arch i buried the bolts and mounting plate in the layup. I re did it in aluminum this year and had it power coated. The last one was SS and weighted over 50#. I installed the tracstar system but for some reason it never powered up. I am debating selling for a couple hundred for parts on Craigslist.
This years revised mount in aluminum with white powder coat
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 29 times
Post by CYO Admin »
Amazing! I'm speachless :worthy:
Mkemper
Post by Mkemper »
After I finished the platform and stairs this past winter I started on the fiberglass radar arch
Starting the plug
Priming and sanding
Ready for gel coat
Gel coat
Mkemper
Post by Mkemper »
The layup
Chop mat
3 layers of 1708 biaxle
Mkemper
Post by Mkemper »
Finishing the inside
Chase for wiring
Panels for closing it up
Closeing up. Fill the space with two part closed cell expanding polyurarhane
