Please clarify Mercruiser 454 open system thermostat operation
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
I am in the process of winterizing my Mercruiser engine. I am a little fizzy on how the open cooling system (raw water through the entire engine) works. Specifically the thermostat. The question is, will the thermostat allow antifreeze to flow though the bock even though the engine is not up to temperature?
This is for future reference...
This year, I pulled all the blue drain plugs (5 of them) on the engine and removed the radiator hose filled the block with antifreeze.
I was looking for a simpler way.
Thanks.
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Please clarify Mercruiser 454 open system thermostat operation
- buster53
- Been thanked: 261 times
Pull the T-stat out first, then run the engine and suck 3 gallons of AF thru. Done.
- Has thanked: 455 times
- Been thanked: 1671 times
- buster53
My way can't be easier. Take out the T-stat, turn on the engine and suck 3 gallons of AF in and done.
And that's for a raw water cooled engine. Fresh water cooled? Same procedure except you don't even need to remove the T-stat.
buster53 wrote:Source of the post So how long does it take you to drain the block, hoses, manifolds, etc?
I take it that what you're saying is you don't drain any of the water? If you're comfortable with doing it that way then so be it but you run the risk of diluting it well below its spec, especially with just 3 gallons of AF. I wouldn't recommend it in any case but certainly not up my way with the winter temps we get here or in NY where the OP is from but whatever floats your boat!
buster53 wrote:Source of the post So how long does it take you to drain the block, hoses, manifolds, etc?.....
It takes me as long as I need to do it so I don't have to worry about it
- buster53
Also, all of my boats have been fresh water cooled, which makes a difference. The only raw water cooled boat I winterized was my son's bowrider with a Merc 5.7 Alpha drive. Took out the T-stat, put earmuffs on the outdrive with a short piece of hose and poured AF into the hose with the engine running. Piece of cake and no issues in the spring.
- amanphoto
Close sea cocks
Clean Sea Strainer / vacuum dry
Remove (5 each side) Blue engine drains - watch for O-Rings
Take a short piece of stiff wire and poke it around in the drain hole to free any rust or scale
V-Drive - remove the two small square headed drain plugs ( front and rear of the upper housing - Water Drain” on the housing
Remove the hose from the lower (rear) end of the transmission cooler. Inspect the cooler for any debris.
Remove front left thermostat hose - drain
Remove front left and right exhaust coolant lines
Port engine - Remove hot water heater hoses (two)
Port engine - Blow out heater hose with air compressor (on low)
Port engine - Attach short loop hose to engine where heater was ~ Port engine
Replace 5 Blue engine drains with O-Rings
Replace V-Drive Drains
Fill left thermostat hose (block) with antifreeze till it comes out thermostat housing - 4 Gallons
Port Engine - Pump Antifreeze through hot water heater hose - 2 Gallons
Fill left exhaust coolant lines - 1 Gallon
Fill right exhaust coolant lines - 1 Gallon
Reattach all coolant lines
Place funnel on Sea Strainer
Sea Strainer - Place a piece of hose in pickup side to the bottom of sea strainer so suck all liquid
Fill sea strainer with Antifreeze
Run Engine until Antifreeze in drained out - 1 Gallon
Put all engine parts together
Loosen serpentine belt for the winter
- amanphoto
I drain all the water our of the engine and v drive through the water drain holes and don't remove any of the hoses. Run the engine and suck antifreeze through the sea strainer....
Question is - Will it enter the block or be pumped overboard because the thermostat is closed?
- amanphoto
It takes a little bit if time. No long, but it can be hard to reach some of the plugs on the sides of the engines against the fuel tanks. Buster53 - remove all the plugs on both engines. While the one engine is draining your removing the plugs on the other engine.
Users browsing this forum: No registered users and 61 guests
