Raw Water Pressure
- dcrahn
- Vessel Info: 1984 Carver 2687 Monterey
- Been thanked: 4 times
Raw Water Pressure
- waybomb
- CYO Moderator
- Has thanked: 53 times
- Been thanked: 426 times
Re: Raw Water Pressure
fwiw - I have 35psi relief valves on PV's engines.
- Has thanked: 455 times
- Been thanked: 1671 times
dcrahn wrote:Source of the post.....I want to add a pressure gauge to my dash so I can keep tabs on what the pump is doing.
It's a good feature to have but I would prefer monitoring the temperature at the exhaust instead. No matter what fails in the cooling system, an exhaust temp monitor/alarm will tell you right away that something has failed even if you have full water pressure after the pump. While monitoring pressure may not catch a problem in some areas, exhaust temps which are at the end of the cooling circuit will react immediately no matter where the failure is. They're on my bucket list for the engines and generator.
- dcrahn
Viper wrote:Source of the postdcrahn wrote:Source of the post.....I want to add a pressure gauge to my dash so I can keep tabs on what the pump is doing.
Agreed! I have 8 EGT sensors in my race cars headers that are recorded with my Racepak Datalogger. I check that very closely after every pass. But, I would still like to know what the raw water pump is doing.
- Been thanked: 615 times
- Has thanked: 579 times
- Been thanked: 1210 times
dcrahn wrote:Source of the post Typically, what pressure range do crank driven raw water pumps operate in, idle up to wide open throttle? I've been a little under the weather lately and have not worked on my project. So, it gives time to think about some improvements and search the web. I want to add a pressure gauge to my dash so I can keep tabs on what the pump is doing.
Where are you thinking to tap the gage into ? The system is open ended so readings will be greatest at the pump outlet and probably close to very little at the exhaust manifold mixing point IMO. Small scale would again IMO give you the best shot at seeing variables.....hope you are feeling better........
- dcrahn
bud37 wrote:Source of the postdcrahn wrote:Source of the post Typically, what pressure range do crank driven raw water pumps operate in, idle up to wide open throttle? I've been a little under the weather lately and have not worked on my project. So, it gives time to think about some improvements and search the web. I want to add a pressure gauge to my dash so I can keep tabs on what the pump is doing.
I am converting to a 1/2 freshwater cooling system and was thinking about somewhere between the raw water pump and the heat exchanger.
bud37 wrote:Source of the post I have an idea....might be a bit anal but.......I might wait until the system is up and running with all new stuff ( impellers etc ) and get a temporary gage and tap some different spots to get readings, then choose a gage to fit, lets say 0-15 or ??....that way you can monitor degradation fairly accurately .....just spitballin....
Kinda like pressure in the slicks 0-30 is useless if you are running 6.5......then 0-15.........woops hit wrong doodad. you get the idea.
- dcrahn
My thoughts exactly! Even though the impeller in the pump looked okay, I replaced it away and I hope to in the very near future fire the engine up in my shop and check everything before it's installed in the boat.
