1995 370 aft cabin
Dainbramage
Vessel Info: 1995 Carver 370 Aft Cabin
1995 370 aft cabin
Post by Dainbramage »
I am looking at this model to use on Lake Ontario. Can anyone share what hull construction standards were for this model in 1995? Where was balsa used? Hull thickness? Deadrise? Any history of delamination? Hull flexing? Core saturation? Thanks.
Re: 1995 370 aft cabin
Welcome to the forum....sounds like you may have been looking at a certain surveyors report ??....anyway I know a few people with that model and they are quite happy, no serious issues.If you go on the Carver yachts site you will see a drop down box under owners and there is lots of info, brochures ,specs etc.....good place to start........good luck man, hope to see you back here...... :beergood:
Been thanked: 492 times
Post by waybomb »
No carver since the mid 80s had coring below the water line.
I've had three carvers and never a hull issue at all.
