I just bought a 1988 3807. And on the port side of the salon just above the stereo on the wall is a switch with A & B on it. Can any one tell me what this is for.
Thank you
The A & B switch on the port side of the salon in my 1988 3807. Can any one tell me what this is for ?? Thank you
- Been thanked: 654 times
Re: The A & B switch on the port side of the salon in my 1988 3807. Can any one tell me what this is for ?? Thank yo
For tv to select input, cable or over the air antenna probaby have a powered antenna somewhere may be hidden in a flybridge access storage if not out in open
That's it g36. There should be an antenna under the flybridge apron in front of the access doors. The other position may have been used for another signal source such as satellite at the dock. It could also be to select a signal for the stereo. Mine had two different antennas.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
It's been 8 years since we had our 3807, but I'm pretty sure the guys are right on this. TV switch and yes, there is an antennae mounted on the flybridge.
Remember that all of the above is correct, and our boat is the same.....but if you are not the original owner there could be all sorts of creative things going on back there from previous folk, still need to investigate to be sure.......
