Carver Mariner 350 Anchoring Technique
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
What do other people do?
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Re: Carver Mariner 350 Anchoring Technique
I think it's there for that purpose. At least, I sure hope it is, that's what I use it for.
Surprised the others don't have backing plates, I now have to check mine. I've held a lot of load (rafting) on those. Seems that many peoples anchors are "defective" and don't get a really good hook.
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- Has thanked: 455 times
- Been thanked: 1671 times
https://www.google.ca/search?biw=1536&bih=772&tbm=isch&sa=1&ei=slWIWqiYF4y6jwTtpoqIBg&q=anchor+chain+lock&oq=anchor+chain+lock&gs_l=psy-ab.3..0l4j0i24k1.53095.55421.0.57116.9.8.0.1.1.0.117.797.3j5.8.0....0...1c.1.64.psy-ab..0.8.687...0i5i30k1j0i8i30k1.0.MrcoNqsIxyY#imgrc=_
- Has thanked: 579 times
- Been thanked: 1210 times
CaptBob wrote:Source of the post Just judging the layout, I would think that cleat #2 was put there just for the solution you need. The previous boat I had (Cruisers) had a cleat there and since we had chain and rode we would anchor, add some slack and take it up on the cleat. That would get the slack off the windlass. Our 360SS has all chain, so I had to get a snubber to attach the chain to the cleat, and yes, there is a cleat right there by the windlass. For a lunch hook, I generally just let it hang, but then again, we are on a pretty calm lake. (as long as the wind stays away)
+1.....that is how we do it.......
- feeez
- Has thanked: 52 times
- Been thanked: 65 times
bud37 wrote:Source of the postCaptBob wrote:Source of the post Just judging the layout, I would think that cleat #2 was put there just for the solution you need. The previous boat I had (Cruisers) had a cleat there and since we had chain and rode we would anchor, add some slack and take it up on the cleat. That would get the slack off the windlass. Our 360SS has all chain, so I had to get a snubber to attach the chain to the cleat, and yes, there is a cleat right there by the windlass. For a lunch hook, I generally just let it hang, but then again, we are on a pretty calm lake. (as long as the wind stays away)
+2.... After the anchor is set we tie off to that cleat with a snap hook on the chain.
Cheers
Fraser......
- denpooch
- Has thanked: 85 times
- Been thanked: 86 times
Besides acting as a shock absorber on all chain rode, regarding load, I am under the impression that is the function of a snubber.
Set the anchor, attach the snubber and let out a bit of chain to release load.
I know that you are a wealth of knowledge and I'd ask if you can you kindly explain what you mean?
Thanks.
- Been thanked: 615 times
g36 wrote:Source of the post Backing plates may be molded into the fiberglass during build and may not be visible just by eyeballing the bottom under the cleat
I believe it mentions Aluminium backing plates in the brochure build specs sheet......
Users browsing this forum: No registered users and 123 guests
