280 - 300 Sedan performance data 1991-1993 model
- Flott
- Vessel Info: 30 Carver Sedan
- Has thanked: 5 times
Hi All,
Is there anyone else out there that can provide any
speed and fuel data on their 1991-1993 Carver 280 Sedan (the 11'10" beam model)?
Flott
Flott
- Been thanked: 654 times
Re: 280 - 300 Sedan performance data 1991-1993 model
The estimator on this website gives you a pretty good idea. Select your engine and see the gph burn at various rpms
http://www.boat-fuel-economy.com/fuel-c ... calculator
That is quite good,you won't go far wrong as G36 says...... it matched my old boat with Gfs 10 flow meters almost dead on.......
- Flott
Thanks g36, thats a big help with fuel burn! Anyone else out there that can help with matching that information up with knots or mph?
- Dusty Bilges
- Vessel Info: Carver 300 Sedan
- Has thanked: 20 times
- Been thanked: 8 times
I just acquirex a 1993 Carver 300 and took it on a 60 mile cruise. I burned 88 gallons, but I am not proficient at findind righr rpm or operating trim tabs, plus occasional headwinds and tailwinds. Could use advice on best ecomomy cruise rpm (assuming calm water) and trimming.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Dusty BIlges, It would help to know what engines you have, what speed and RPM were you running at
- Dusty Bilges
Buster-
I was all over the place with RPM's and speed as I was trying out different settings. My question is whether as a general proposition, all things other things being equal, what is typically the best speed and rpm's for maximum economy on a Carver 300 Sedan. I have two Mercruiser 5.7's (350 Chevy's). They are either 260 hp.
- Craig_B
- Vessel Info: 1988 Carver Santego 3067
- Has thanked: 144 times
- Been thanked: 13 times
I too would like to know . will be watching for answersAnd I can't figure out the trim/tilt gizmos either
Pictures of our 1988 Carver Santego
https://www.flickr.com/photos/giarc_dra ... 7558217844
The rest of our picture albums.
https://www.flickr.com/photos/giarc_dranrab/albums
To really make that matter, you have to figure out what your time is worth.
Best efficiency is below hull speed, so you're not even on plane. That's probably around 7-8 MPH, but it will take you forever to get anywhere.
An easy way to get a good estimate for the most efficient cruise speed is to get up on plane and then back down gradually until you feel the boat start squirming around or start to fall off plane. Just above this speed is typically your most efficient cruise speed. It will be a bit slower than a "normal" cruise speed but will likely have the lowest gal/hr burn while up on plane. We frequently use this speed if we're just site-seeing around and going nowhwhere in particular. If we're actually going somewhere, then we bump the speed up a bit to a normal cruise so we arrive at a reasonable time at the destination. It burns a bit more fuel but gives us more time to enjoy where we're going.
- Capn Crunch
- Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard - Location: On the Mighty Columbia River in the Pacific Northwest
- Has thanked: 87 times
- Been thanked: 7 times
When asking the same question locally I was told the following (using numbers from above referenced website) :
One local destination is about 39 miles one way down river. On my Montego 2557 w/5.7 Mercruiser 2500rpm is about 9.5mph @ 6.6gph. 3700rpm is about 26mpg @ 11.5gph. 4 hrs @ 6.6gph = 26.4 gal VS. < 2hrs @ 11.5gph = 23 gal... Sometimes less really is more.
