Best way to measure out oil change
- VolNavy91
- Vessel Info: 1997 Carver 400 CMY
1st Date
Paris Landing, TN - Location: Bartlett, TN
- Has thanked: 17 times
New to diesel maintenance so advise would be appreciated. When buying oil in bulk by the gallon or 5 gallon bucket, whats the best way to measure out if you don't need the entire container- in my case the engine capacity is 15 quarts - less than 5 gallons and 3 quarts more than 4. How do you measure out that last fractional amount?
PJHoffnet
- Has thanked: 55 times
- Been thanked: 18 times
Re: Best way to measure out oil change
Buy a couple of quarts of oil. Use them in your next change and then retain them as your 'smaller amount' measures. Fill from 5 gal supply as needed.
