Carver
Re: Engine Temps are Off
Do you have an IR temp gun....if so shoot each engines thermostat housing or right on the sender itself, that will give you an idea of what is up.....the IR temp guns are cheap now and in my opinion a tool that is mandatory on a boat. That will get you started.
nautiyachti wrote:Qr Bbpost i suspect I'm still in range but I noticed that my engines are reading different temps.....
Could be a number of things causing that; wiring, corroded contacts and or plugs, faulty gauge or sender, or actually reading correctly and reflecting true temps at the engine. I wouldn't expect them to be exactly the same but pretty close otherwise there may be another issue at the engine end providing the above items all check out. As Bud mentioned, taking temps right at the engine is your best bet to compare with the readings at the helm. They won't match because you're taking an external measurement but it'll give you an idea/starting point.
nautiyachti wrote:Qr Bbpost..... some of my gauges have developed a haze of sorts on the lens.....
I've heard that some gauges are sealed and some are vented to atmosphere. If sealed and you get fogging, the seal has likely failed. Anything exposed to atmosphere will eventually accumulate pollutants that are impossible to get out without dismantling the gauge. The problem is that most are pressed together and not meant to be taken apart. Some gauge manufacturers like Faria will repair their gauges for a fee. Probably not worth it though for lower end units by the time you pay for the repair and shipping, etc. I doubt your vintage would be under warranty.
