Main breaker type
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 211 times
Main breaker type
Hi everyone, need to know what type and brand of main shore 1 breaker is being used. We need to replace it as the it is finished. It is and has 3 breakers rivited together. 2004 360 Sports Sedan. Thanks in advance, Andrew
Re: Main breaker type
You can checkout the parts listing for your boat if available at Carver Yachts....but if you remove the bad one there will be a info right on it or should be, then you can replace in kind, common stuff.
Since you have a newer boat, you can probably email Carver and they could give you the manufacturer and part number.
That main likely has a built-in reverse polarity sensing circuit, so make sure you replace with similar.
- pepmyster
8.1 Volvo Penta
Emailed Carver, Chatted with Pat Johnson, We are ordering the original today. Very fast response and very resonable price for the breaker. Great customer service!!!!!!!
- pepmyster
8.1 Volvo Penta
All installed, NOW it's perfect! Thanks to the Carver parts dept for their fast service!!!!!!!
- pepmyster
8.1 Volvo Penta
PART- 8900333 BREAKER:30A 3 POLE MAIN
Carling Tech
Carling Tech
