Window channel replacement
- Polarman
- Vessel Info: Metanoia - 1993 Carver 370 Aft Cabin. Twin 7.4 L Crusaders.
- Has thanked: 1 time
We have recently purchased C 370 Aft Cabin. (1993). The window channels in the salon and the aft stateroom are deteriorated and mossy. Where can I find replacements and what should we know before we attempt to replace them. Thanks.
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
Re: Window channel replacement
Polar - We have same situation. I obtained some info from Taylor Made Systems. Doesn't spell out the process but is helpful nonetheless. Will share - send me message with your email.
- Polarman
Not sure best way to get this to you. Still new at this blog. Seems like an older format. Please contact me at mike@upnorthpowersports.com
Thx
Thx
- Sonofdivver
- Vessel Info: 1995 430 Cockpit Motor Yacht
I'm about the same situation with my 430 cockpit motoryacht.. Could you please forward the information to me as well? Dallenjr@sc.rr.com I really appreciate it.
1995 430 CPMY
315 Cummins
Home Port: Little River SC
315 Cummins
- ronmar
- Vessel Info: 1993 350 Aft Cabin
- Has thanked: 21 times
I as well have same issues on a 93 350 Aft Cabin. Would love to know how to replace. I'm having some leaking issues and think possibly the cause.
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
If someone has the info on replacing that weatherstripping and could post the process that would be awesome. I believe it's called schlagel or something like that.
I'm wondering if the windows have to be split in order to install it.
Mine are mossy, which I was able to clean out, but also bits are missing.
- quickdecision
- Vessel Info: Carver 3807, 1987
- Been thanked: 23 times
Just finished rebuilding the salon windows in a 3807. Bottle jack and 2 x 4"s allowed windows to be removed easily. Frames removed, cleaned, repainted. Re-bedded with butyl. Do not tighten screws all the way at first. Use 1/8" spacers. After about 2/3 weeks pull spacers and snug screws the rest of the way. Installed slick tape in the bottoms of the channels. This made the windows slide with one finger. DK hardware has the weather seals that seals the windows to the tracks. Make sure you clean the drain holes in the window frames. This is a major cause of leaks. Below are the companies that supplied the materials. Butyl can be bought from many sources. This is the material used to seal you car windshield in.
Ron
http://www.eplastics.com/slick_strips
http://www.dkhardware.com
Ron
- 1992330aftcabin
- Vessel Info: 1992 330 Carver aft cabin
- Has thanked: 54 times
- Been thanked: 32 times
I have the same issue, can you share the info from Taylor? Mikelarson1959@gmail.com thanks Mike.
- StDuckie
- Vessel Info: 1991 3607 Aft Cabin Cummins 6BTA
- Has thanked: 29 times
Hello all, I too have Taylor Made windows...please share procedure for replacing sliding window channel. Thanks to all. Doug
