New breaker doesn’t fit?
CptBacardi
Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
Has thanked: 3 times
Postby CptBacardi » July 21st, 2018, 2:43 am
Hi! New Carlingtonswitch breaker (left) does not match the connections on the old one (right). The new one has wider plates on it which the old connections don’t fit on to. This panel has the bus bar thing on it that connects all the breakers with a single metal bar, so modifying it to work is a PITA. I’ve looked everywhere. Does Carlingtonswitch have a different 10amp part number with the old, smaller plates, connection types on it? Thanks
Been thanked: 1043 times
Re: New breaker doesn’t fit?
Postby km1125 » July 21st, 2018, 10:33 am
Yes, they do make both. The part number should be on that tag. The left is ONLY for screw-on terminals and the right is for push-on. Both can be used with a buss-bar, but the bar is a bit different for both.
CptBacardi
Postby CptBacardi » July 22nd, 2018, 6:01 pm
I found a AA1-B0-22-610-1D1-C part number on eBay. The “1” in “1D1” means push-on termination for anyone that may see this later. Hope it helps you.
Postby km1125 » July 22nd, 2018, 9:32 pm
Somewhere on the Carling website is a decoder so you know what all the numbers mean in their part numbering scheme.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 474 times
Been thanked: 201 times
Postby pepmyster » July 23rd, 2018, 9:43 am
I also made a mistake, see my posts, for the main breaker on our boat. I contacted Carver parts dpt and they got me the correct one.
Users browsing this forum: No registered users and 114 guests
