Which bilge pump switch?
- CptBacardi
- Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
- Has thanked: 3 times
- Been thanked: 615 times
Re: Which bilge pump switch?
you can use this refernce pdf i listed to configure the switch then google that number
http://www.carlingtech.com/sites/defaul ... 26_COS.pdf
heres some on also
https://www.searay-parts.com/Lighted-ti ... -s/121.htm
- CptBacardi
- CptBacardi
- Has thanked: 268 times
- Been thanked: 1153 times
CptBacardi wrote:Source of the post I am confused about the switch still. It only has 3 tabs. One is for ground. The other 2 wires are both labeled B6. This makes me think it only switches one circuit “on-off” I’m guessing for continuos. Does the auto circuit just always have power on or something? Does this helm switch just control “on” for continuos and when it’s off, the auto circuit is still on? I don’t get it... would an on-on switch have more then 3 tabs???
The switch when put into continuous turns on the pump, only way to turn it off is to put it in the auto position. When in the auto position, the float switch will turn it on depending on the float switch level.
Yours sounds like it is wired like this
- CptBacardi
- Has thanked: 579 times
- Been thanked: 1210 times
- CptBacardi
