Carver 444 cabin lighting to LED
Topic author
Tomion
Vessel Info: Carver 530
Been thanked: 2 times
Postby Tomion » August 19th, 2018, 9:37 pm
Just completed replacing all my cabin lighting to LED. Bought them on Amazon for 160$ for 30 lights. Came out excellent. Pretty easy job. I have about a dozen gold trim rings that arent cracked if anyone would like them. The
Been thanked: 261 times
Re: Carver 444 cabin lighting to LED
Postby buster53 » August 20th, 2018, 7:28 pm
PM sent
Easy Livin
Vessel Info: 2001 Carver 396 Motor Yacht
Postby Easy Livin » September 5th, 2018, 10:56 am
Did you replace the whole fixture? Do you have a link? I am looking for replacement fixtures for mine.
jspin101
Vessel Info: 2005 Carver 41 CMY w/ 2006 Volvo D6 370I-B's
Has thanked: 8 times
Postby jspin101 » September 5th, 2018, 6:13 pm
I replaced mine on my 2005 41 CMY. I got the 194-R-90 (red) bulbs for my courtesy lights from superbrightleds.com.
For the salon, staterooms, bathrooms I got
BAILIDA G4 LED Bulb, 12V JC Bi Pin Bulb, 20W Halogen Bulb Replacement, Daylight White 6000K, 5-Pack and
BAILIDA G4 LED Bulb, 12V JC Bi Pin Bulb, 20W Halogen Bulb Replacement, Warm White 3000K, 5-Pack on Amazon
What a difference, no heat!
Hope that helps.
Postby buster53 » September 5th, 2018, 7:32 pm
I got a 10 pack bi pin replacement bulbs from Amazon for $12. The halogens were around 200 degrees. The LED's are under 120.
Marty
Vessel Info: 2000 326 AFT Cabin
Has thanked: 16 times
Been thanked: 9 times
Postby Marty » October 19th, 2018, 4:39 pm
Did you replace the trim as well? If so where did you pick them up as I have beige plastic trim(s) that a few have cracked.....and would like to replace with brushed silver or nickel.
Thanks,
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » October 19th, 2018, 6:04 pm
Users browsing this forum: No registered users and 119 guests
