Genny Died
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Genny Died
A solid no start condition. Cranks, but does not fire. No cough, no attempt at start, nada, nothing. Simply spins at a normal sound that it always had. (I've already pulled the drain plug on the water lift muffler so that I will not waterlock it while trouble shooting)
The patient, a 7.3 Kohler carb genny.
Oil full.
Coolant full
Port fuel tank at 3/4 (genny draws from port)
Impeller intact, water pumping through to muffler, (and currently draining out of muffler)
Replaced plugs (don't remember doing the annual plug change ritual this spring)
Check for spark at plugs, both have spark.
Pulled fuel hose off output side of genny fuel pump, no fuel while cranking. So that's a problem.
Check for power going to pump while cranking, no power on multi meter. I would think that's a problem.
Questions, I suspect whatever drives the pump (the dreaded board in the controller on the genny, or a possibility of a fuel pump problem since I'm not sure what I should get out of the plug to the pump, I would assume 12 VDC. I did not check to see if the transfer pump was moving fuel to the genny pump, nor did I remove the fuel filter that is upstream from the genny fuel pump. I stopped when I found no power to the pump. I'm kind of in the process to try to find a "proper" test of power to the pump.
Other suggestions?
Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Genny Died
- Been thanked: 1043 times
Re: Genny Died
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
Re: Genny Died
- CaptBob
Re: Genny Died
Keith S wrote:Source of the post The fuel pump shares the same fuse and relay as the ignition, so if you have spark, they should be fine. Check the 2 conductor plug at the fuel pump, I have seen them corroded enough that no voltage would pass. Separately power up the fuel pump and see that it works.
Well, I went back in during this weekend to have another look. I was prepared to jumper some power to the pump and see if I had flow. However as an additional test I decided to probe the plug again and see if there was power to the pump. There was. I have no idea why I didn't have power the other day, possibly I was grumpy and measuring the wrong end of the plug, or probably I had the meter on the wrong setting, (I don't use the boat's multi meter near as much as I use my work one... )
Anyway... a new pump is on order, we will see what happens!
- daveS
- Vessel Info: ☀️Sanity Sol☀️
1999 350 Mariner - Location: Penetanguishene, Ontario
- Has thanked: 24 times
- Been thanked: 8 times
Re: Genny Died
- Has thanked: 324 times
- Been thanked: 595 times
Re: Genny Died
- Keith S
Re: Genny Died
- CaptBob
Re: Genny Died
- CaptBob
Re: Genny Died
It was the pump. A new pump and filter later, it roars to life and settles down again like a normal genny should. Happy now, off to enjoy tomorrow with AC and all the goodies that go along with it. It's not so much as needing it, it just annoys me when something is down. Much happier boat (and crew!) when all is well.
Side note. In my searching for the pump, I found the same model number as an automotive application. (for half price of course) I did get the marine version, but upon removal of my old one, I see the sticker on the old one stating an automotive. It was painted over white as the rest of the genny. I do not know if it was original or not, (I seriously doubt it) but figure more likely that it was purchased and then painted as a replacement.
Users browsing this forum: No registered users and 119 guests
