Onan 6.5kw Marine Genset Cooling
- bmalmquist
- Vessel Info: 1995 Carver 370 Aft Cabin
- Has thanked: 1 time
We recently purchased a 1984 Carver 3207 Aft Cabin with an Onan 6.5kw Marine Genset. The generator ran great for a couple of trips but just yesterday I went to start it and it did not appear to be circulating any water (this is a freshwater cooled system). I assume there must be a safety shutoff as the generator powered itself down after about 60 seconds.
I am thinking that I will need to replace the impeller but have read that it may have just lost siphon? Is that possible, and if so any hints on how to remedy?
Is it a big job to replace the raw water impeller?
Does anyone have a manual for that year Onan generator?
I have owned many inboard/v drive boats as well as a few older RV's and have done all the work on them myself.
I searched the forums but could not find anything specific to my year/model.
Thank you in advance for any expertise you can provide!
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Onan 6.5kw Marine Genset Cooling
- bmalmquist
Thanks again!
The tank , if it is black fibreglass is probably the muffler for the generator.....if you have a pic of this, it can be verified as to the type.
- Has thanked: 455 times
- Been thanked: 1671 times
https://isurplus.com.au/manuals/Onan%20MCCK%20Marine%20Genset%20Manual.pdf
Replace your impeller. You need to start with a fresh one anyway so that you have a record of when it was last done.
- bmalmquist
I am used to changing my raw water impellers every year in my Malibu Wakesetter towboat, I have been told that it could be a little aggressive to be doing all my impellers on the Carver every year.
It only takes me about 20 minutes to change the towboat impellers, how big of a job is the impeller on the Genset?
- bmalmquist
Any special grease I should put on it for the initial start?
Users browsing this forum: No registered users and 57 guests
