Sharp Carousel Micro Convec Oven replacement.
Tomion
Vessel Info: Carver 530
Been thanked: 2 times
Post by Tomion »
My 2001 Carver 444 Has a Sharp Microwave / Convection oven M# R820BK I need to replace as the digital readouts are bad. Ive been told dont try and fix but replace. I am having difficulty getting it out. The front bottom foot pads had some tacky substance on them I broke loose but still wont budge. There doesnt seem to be any acces point to get to side bottom or top.
Re: Sharp Carousel Micro Convec Oven replacement.
Lots of times they are screwed in from underneath.....picture they are sitting on a wood piece that has screws that come from below, maybe behind a light.....somewhat ingenious, just have a real good look.....the one in ours had a screw behind the mount for the blinds ...... :-O
before you just replace, go look for the part on repairclinic.com. They have pretty good prices on stuff and it might not be that expensive or hard to do.
(that is, if you liked it. If you never thought it was that great, then go find a good one to replace it with)
BigRedandJodie
Vessel Info: 2002 Carver 444 Motor Yacht
6BTA Cummins 370hp Diesels
Post by BigRedandJodie »
Hi, did you ever figure out how to remove the microwave? I’m in the same position. Thanks!
“Nauti Girl”
Glohmann
Vessel Info: 2002 Carver 396.
Purchase August 2020
First “big” boat we have owned.
Post by Glohmann »
Any luck figuring out how to remove the microwave? I need to replace the one in our 2002 Carver 396.
thatchh
Vessel Info: 2004 Carver 396ES gas Crusader 8.1
Has thanked: 5 times
Been thanked: 11 times
Post by thatchh »
Which galley do you have? I have the 2004 extended salon model with the under counter refrigerator and stove on the forward bulkhead. I removed mine to add an exhaust fan for the stove. My recollection is that once I removed the trim around the front. I was able to remove any front mounting screws and withdraw it. I do agree, they may hide some fasteners. On the ES, you can remove the panel in the back of the locker of the forward cabin and access the rear of the unit, but I don't remember having to remove fasteners inside.
