50 amp female to a 30 amp male
- Vessel Info: 1998 Carver 405
- Has thanked: 234 times
- Been thanked: 38 times
In the meantime, can I convert the 50 amp using a 50 amp female down to a 30 amp male converter and it work? So I dont have to run my generator all the time.
I have 2 16k btu a/c units currently and I plan on adding a 3 16k btu unit next summer.
Electrical is not my strong point, so if I run separate convertors from the 2 connectors on my boat will it power everything from the 30amp connections? I have two separate connections on my shore power pedestal I can use.
I havnt even started adding my large screen tvs, so i appreciate any thoughts or suggestions ya have
- Has thanked: 268 times
- Been thanked: 1153 times
Re: 50 amp female to a 30 amp male
If you do not know what you have, post a picture of the plug end of your 50A cord. The side that plugs into the pedestal showing the prongs in the picture.
- buster53
- Been thanked: 261 times
- buster53
You might want to rethink that 3rd AC unit. 48000 BTU's for that boat will be overkill. Nothing wrong with having a 3rd unit, but drop back to a 6k or 9k unit
I had hoped to duct a couple a/c vents up into the helm and the area under the hard top from the 3rd unit. Boat is parked under a covered slip and I am going to back it up to listen to bands at a restaurant. So you are correct, it may be overkill with another 16k.
I do agree, I think it is a 250/125 system but here are the pics.
- buster53
I can clearly see the 50a, but I can only see 125v. Does it also say 250 as well, but just hidden by the plug blade?
BTW, a large screen LED TV, uses very little power. AC, cooking and water heating is your big power draws. We used to turn off the water heater whenever we were cooking or anytime someone wanted to use a hair dryer. It's all about electrical management.
As for a 3rd AC. I also think that would be overkill. I have a 9 an 11 and a 14 for a total of 34,000 btu. Apart from electrical draw there are other things to consider such as the increased water flow demand to address if you add to the existing system. Just food for thought.
- buster53
The only other option is to replace your current boat side plugs with 30 amp.
We had our 3807 for 7 years. Up thru year 5, we just used the special cords we had. Year 6, we replaced the boat side plugs. Halfway thru the job, past the point of no return, we decided we wished we had left well enough alone.
Have new cords made. It is the simplest option.
I am still wondering and hopeful the boat is different. So let me take some pics in the next couple days
Users browsing this forum: No registered users and 113 guests
