What Is This Thing???
- fleck05
- Vessel Info: 1983 Carver 3607 Aft Cabin
- Has thanked: 20 times
- Been thanked: 4 times
- Contact:
I have a 1983 Aft Cabin 3607 and have been wondering about a wood square on the port side of my hull (pictured). The wood is rotting apart but since whatever used to be attached has been cut I never really tried to figure out what it is... but I am curious. Maybe something to do with grounding at some point? Thanks.
Re: What Is This Thing???
My guess is an old transducer since there is what looks like a wire coming out of it.
Looks like a few old ones down there, or is that the same one in both pics.....what are you thinking to do ? Maybe on the list next haulout, bottom job?
Ya looks like an old ducer. Before it starts leaking, remove it, remove the wood backer plate, and have a fiberglass tech patch the hole properly or use the same hole to install a new ducer for a new sounder, or seacock for a future upgrade, etc.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Is it possible that is a transducer that shoots thru the hull and there is no hole there?
It looks like there is a tightening nut on a threaded shaft there which shoot-thru-the-hull types don't have.
I would say old transducer too.
I have an 83 3607 as well. Do you have a generator? Is that silver thing the muffler for it?
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Already answered but that is most likely an older in hull transducer. Looks almost identical to the in hull transducer I currently have on my 3007.
- fleck05
- Contact:
Thank you for the answers.
"Looks like a few old ones down there, or is that the same one in both pics.....what are you thinking to do ? Maybe on the list next haulout, bottom job?"
Just the one, I was showing its location. I need to haulout sometime in the next few months and replace the exhaust pipe (tube?)... exhaust thing with date on it. The starboard side was replaced, but the port was not and I'm getting drips coming in - the date on that tube is a lot older than the starboard one.
"Before it starts leaking, remove it, remove the wood backer plate, and have a fiberglass tech patch the hole properly"
This was a curiosity... when the wood rots through can it leak?
"It looks like there is a tightening nut on a threaded shaft there which shoot-thru-the-hull types don't have."
So maybe it won't leak if the wood rots?
"I have an 83 3607 as well. Do you have a generator? Is that silver thing the muffler for it?"
Yes - that is the muffler for the generator.
Thanks for the info - your answers have given me a great place to start researching. The boat is only a few months old to me and I'm about to dive it and clean it for the first time. If it goes through maybe I'll be able to tell from underneath. I'll follow up on this thread if I find something out that's interesting.
Thanks again.
Thanks again.
The nut is what's fastening the ducer to the hull. When a backer plate rots, the whole assembly becomes loose and allows movement. Eventually the movement causes the seal to fail and leak.
