444 / 396 enclosed aft deck drain scuppers
extraextra
Vessel Info: 1998 405, 2005 444
Post by extraextra »
On the aft enclosed deck of my 444 there are 2 drain scuppers. (they maybe there on a 396 also) They are in the rear of the deck, one in each corner. Does anyone know where they drain? One is blocked and water will not drain. Since they are in the enclosed area, they are not subject to debris or leaves. Any ideas?
Re: 444 / 396 enclosed aft deck drain scuppers
Spiders/ wasps etc....shop vac it out ...we regularly clean many of our drains that way.
extraextra
Thanks Bud37, do you know where they drain out?
Page # 202......just below the rub rail.....hopefully this is your boat... :-D
https://carveryachts.blob.core.windows. ... 4537v1.pdf
extraextra
thanks for the link, It may sound crazy but my thru hulls don't match up to the diagram at all. I check again this weekend when I go back to the boat.
Peter
Vessel Info: Carver 38ss 2007
Has thanked: 23 times
Been thanked: 7 times
Post by Peter »
If they are the same as my 38Sss then they drain out on the rear transom below the swim platform look like exhaust flaps
Mine were blocked
