Shaft Packing Leak?
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 38 times
- Been thanked: 11 times
Shaft Packing Leak?
Thanks in advance,
Vic
- Been thanked: 620 times
Re: Shaft Packing Leak?
- Cooler
- Has thanked: 68 times
- Been thanked: 399 times
https://carveryachts.blob.core.windows. ... bin_88.pdf
- VicB
You are probably right. I measured them a while back and since then, I have done so much in that engine compartment that I would bet you are correct and i have my numbers confused. Last night i ordered 1-1/4 hose and all week i've called everything 1-1/4. I've got to quit watching so many Youtube videos. It all starts running together.
- Has thanked: 585 times
- Been thanked: 1231 times
- waybomb
- CYO Moderator
- Has thanked: 56 times
- Been thanked: 444 times
- Has thanked: 72 times
- Been thanked: 1054 times
I have a 3607, so a similar but slightly smaller boat. I have 1 3/8 inch shafts.
I used these wrenches to adjust the packing. I got them from home depot and they aren't that expensive (and handy for a LOT of other things too). Get two and you can also use some short lengths of pipe if you need more leverage. Also, as waybomb notes, check the direction of the threads to make sure you're turning the right way or you'll never get things loosened up!!
- Cooler
Careful when adjusting, too tight can create heat. Heat creates burn. Burn creates $$$. It is normal for standard shafts to drip a little while running. Some don't, but most do.
- Redemption
- Vessel Info: 1982 Carver 3607
Users browsing this forum: No registered users and 62 guests
