What Is This Thing!
Tomb266
Vessel Info: 1991 Carver 430 cockpit MY
Has thanked: 5 times
Been thanked: 4 times
What Is This Thing!
Post by Tomb266 »
:banghead: Ok, hi to all! I have a 1991 Carver 430 cockpit motor yacht. It is my intent to crawl through and into every space that I can to better know what is what and how to properly maintain it. I discovered a cap on the starboard aft under the exhaust outlet. I unscrewed the cap and there is this bolt/screw that I have no idea what it is or what it does. :confused: Nothing in the manuals, drawing or on the Carver website. :-( Any help greatly appreciated.
Tom
Re: What Is This Thing!
Post by tomschauer »
Most likely the flux capacitor connection point. :-D
Just kidding of course, sent a couple pics, someone will know what it is.
If that is on the transom could it be a platform support bolt and I agree a pic may help...... :beergood:
Tomb266
Post by Tomb266 »
Thanks for the humor :approve: Not a platform bolt as it seems to be for some adjustment. I looked inside the hatch on that side and there is a 4" pipe (tube) that runs along aside the hull the length of the starboard side. I will grab a couple of pics when I next go down. I am sure it will be obvious to someone instantly.
All the best! :-D
Tomb266
Post by Tomb266 »
Okay, back from the boat and took these. Hopefully someone can tell me what it is and what it does. :-D
download/file.php?mode=view&id=2511http ... ew&id=2510
Don't know what that is, you definitely come up with some good ones... :-D .....but you really should look into whatever is rusting there.....something is improper/ needs sealing etc.
Did this boat have transom lights before ?
throwback2
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Post by throwback2 »
Is it a spare shaft?
Tomb266
Post by Tomb266 »
Yeah, this power boating certainly has been a exploration of many unknowns. No I don't believe she has ever had lights. The rusting is among the many similar such that I will be addressing as the weather here in Alaska improves. Spare shift......hum, you might has something there. I think the best approach is to try to remove and see for sure, but that just might be what it is.
Sadey
Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Benedetto
Has thanked: 4 times
Been thanked: 29 times
Post by Sadey »
Turn signal fluid refiling point? Oh wait it's a boat not a car, never mind.
Thank you for the help!
Dave & Trina
Tomb266
Post by Tomb266 »
I thought about that but, I could not find where to replace the bulbs. Ugh! I also thought it might be to adjust or align the boat so it would run straight when under way. We shall see when I remove it later this month. :lol: I will post back then.
