Windlass shopping
ataylor233
Has thanked: 83 times
Been thanked: 7 times
Windlass shopping
Post by ataylor233 »
I have a carver 3207 aft cabin ... i need a Windlass i've been shopping and i've come up with a Lewmar V700g windlass does anyone have this? i'm not worried about the install that's the easy part for me the hard part is making the choice and getting the right equipment. i have a bout 10 feet of Chain and 200 ft of Rope. any advice would be appreciated.
Re: Windlass shopping
I installed a Good Automatic on the last boat.....solid, solid stuff, quality parts/ switches/ relays made in the US, there were no offshore parts in the one I had......nice people, family outfit in NJ......check em out.
If I had to replace the Maxwell on the boat now I would get the Good. Thats my 2 cents...good luck man....
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
I have that windlass and LOVE it! replaced the ancient GOOD WINDLASS. Would never go back!
ataylor233
tonyiiiafl wrote:QR_BBPOST I have that windlass and LOVE it! replaced the ancient GOOD WINDLASS. Would never go back!
Thanks are you using Rope and Chain or Just Chain?
tonyiiiafl
been away. YES! I am using 8 plait with 25' of 5/16" chain. I would like to get to 50' of chain, but this combo works just great as is. Total Rhode is 300'.
ataylor233
last question what gauge wire did you run from the batteries ? om ordering the wire in a day or so and i'm confused between 2 awg and 2/0
I believe 2/0 is bigger than 2 awg.......actually the wire size you need depends on the amp draw and the total length of run from the batteries to the windlass, both ways...so if the batteries are 10' from the windlass then you need to use 20' as the total. You will need to consult a chart to help with that .....sorry I don't have one, I am sure someone might have a link....
The size of wire you'll need for your particular installation really depends on the length of the circuit from the battery bank to the windlass. That could be different for every install even with the same boat model and windlass as one installer may have run the wiring through a different route affecting the circuit's length. Before you buy the wire, plan your install and where you'll route the wiring. Measure the length of the circuit which is from the battery to the windlass and back to the battery. Then check the installation manual. It will tell you the size of wire you need for the length of the circuit you've measure based on your planned routing. Don't cheap out here or you'll have less then optimal performance. If the spec indicates a wire size but the numbers are close to the next size up, get the next size larger as this will give you a better margin for error and minimize the effects of other variables that will affect performance.
Yes 2/0 is larger. Unlike the other end of the spectrum where wire gets smaller as the numbers get higher, */0 wire gets larger as the number gets higher.
tonyiiiafl
I used 1/0. I had a 20’ run
