We have our survey/sea trial next week for a 1991 Command Bridge 26. Not a lot of info on the interwebs that I’ve been able to find, so hoping to learn much here.
The engines are 4.3’s, new in ‘16 with 7 hours on them. Outdrives replaced in ‘17. New head, and a hard top over the bridge.
We are moving up from an ‘03 Sea Ray 225 Weekender, our first boat.
New member
- Flying Beagle
- Vessel Info: 1991 Command Bridge 26
Twin 4.3’s new in 2016
New outdrives in ‘17 - Location: Stafford, Virginia USA
New member
16’ Ski Barge
22’ Sweetwater Pontoon
1991 Carver Command Bridge 26, new twin 4.3’s in ‘16, new outdrives in ‘17
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Re: New member
Good luck! Make sure your surveyor does a comprehensive moisture analysis on the hull and topside. Can't recall if the hull was cored or not, but the topsides are balsa cored. Hope it all works for you and we get you in the Carver gang. Let us know what happens!
er
- waybomb
- CYO Moderator
- Been thanked: 492 times
Re: New member
Good for you!
Re: New member
Welcome to the forum and hopefully Carver.....good luck with your upcoming trial and survey......
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: New member
Welcome Aboard. Good luck and we all hope it works out well for you.
