High amp inverter/charger install
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
I’m in the process of finishing my inverter/charger installation. My question is whether the isolator(alternator) cable can be connected to the battery when the charger can output as much as 120amps? I have two isolators that appear to be 70amps each tied in parallel.
Re: High amp inverter/charger install
Is that one isolator from each engine?
Not sure I exactly understand your question. Are you concerned about the charger causing a problem with the engine or alternator?
darrenlife
Yes, concerned that the high amps from the charger could do to the isolators? I realize that isolator is basically a one-way valve but will I be okay since the two 70 A isolators appear to be in parallel?
It's not the amps that would affect the isolators, it would be the volts. I don't think you'd have any issue. I'm assuming those are diode isolators. If an isolator gets a VERY high voltage (spike) on the output side then it could damage it, but I would not expect anything like that from your charger, especially when it's connected though the batteries, as they are a very good buffer to voltage spikes.
darrenlife
km1125 wrote:Qr Bbpost It's not the amps that would affect the isolators, it would be the volts. I don't think you'd have any issue. I'm assuming those are diode isolators. If an isolator gets a VERY high voltage (spike) on the output side then it could damage it, but I would not expect anything like that from your charger, especially when it's connected though the batteries, as they are a very good buffer to voltage spikes.
Great, thanks for your input, greatly appreciated!
You may already know everything there is to know about these but see this just in case. https://www.youtube.com/watch?v=urBq9k-kaTM
